-   Mercedes CLK Class (https://mercedesforum.com/forum/mercedes-clk-class-12/)
-   -   Cabriolet roof problems (https://mercedesforum.com/forum/mercedes-clk-class-12/cabriolet-roof-problems-49620/)
ozyael Oct 3, 2011 01:20 AM
I have a CLK230 cabriolet 2000 model year.
The roof's red light flashes and probably one of the sensors showing the roof was still open.
If you can get advice and help how to solve the problem?
If you can get the program Digrmh of all electrical system of the roof, or buy the book with all the plans.
Because the problem I can not open the trunk electrically, only with a manual key.
I'd love to get an answer
Have a wonderful day
OZ :)
ozlaw100@gmail.com
ozyael Oct 6, 2011 02:51 PM
There is a chance to get here an answer or help???
ratanshah Apr 8, 2012 11:17 AM
If you need manual try MBUSA site.
It may be pump. Do rear headrests go up with control.
It is complex hydraulic pump system.
ozyael Apr 10, 2012 04:53 AM
Thanks for the answer
But my problem still exists.
When the roof is closed I can not open the trunk, only with the key is opened.
The flashing red light and beeps 20 seconds when I start to drive
With the top down no problem, regular open trunk
Probably one of the switches shows that the roof is still open even though the roof is closed.
If there is any one of you advice and can help me?
Thank you
OZ
geoff60 Apr 10, 2012 11:30 AM
Same problem
Hi ozlaw100
I have a CLK 320 same year and have the exact same issue, I know this doesn't help solve your problem but I am working on a solution so I will keep in touch if I come up with any thing I will let you know. Good luck.
OZ :)
ozlaw100@gmail.com
ozyael Apr 11, 2012 12:47 AM
I'm pretty sure the problem is SWITCH 2088202310 FOLDING TOP DRIVE
Where can I buy the part ??
