bad cold starting
[align=left]CLk 320, when first cranking from cold, engine fires and stalls, after several attemps fires but lacks power, will not rev, allow engine to idle and it comes in on all cylinders
Fitted new, tdc sensor, engine temp sensor, fuel pump, fuel filter, plugs and air filter. Fuel filter has a vacumm operated valve fitted, where is the vacuum pipe from... ?? Fuel pressure regulator? where ? Any info would be appreciated, many thanks. [/align] |
