Adapting Stereo for iPhone/iPod
Does anyone have advice / suggestions on how to adapt the stereo in a 2003 CLK 55 AMG to be able to play music from an iPod (iPhone 4 in my case)? I was able to do this using an adapter from Crutchfield on a 2000 Audi A6 I own, but they did not have anything that would work similarly for my CLK. The Audi solution involved attaching an adapter through the in-trunk CD changer. While the CLK also has an in-trunk CD changer, Crutchfield did not have an adapter that will work with it (something about being a digital interface on the CLK). -Al
Originally Posted by cyberine2k
(Post 154202)
I have 2002 CLK cab and i use it that way. |
Glovebox adapter
Thank you - I had no idea there was an adapter in the glovebox. I have a proper cable, but another question. How do I set the receiver to play the audio from this source? I don't see an auxiliary setting or anything.
-Al |
Do you have " command " on your CLK ?
If you do I can walk you thru. I have 2002 so there may be some difference. rs |
Thank you, RS. I mis-typed. It is a 2002. And yes, it has the COMAND system. I have only owned it since July and am enjoying cleaning it up from the previous owner. Are you still happy with yours? How many miles? -Al
From Setting button on command you will see "Auxiliary" Option
highlight and press button to go to it. ( keep volume high on your iPod or iPhone ) control volume with controls for Radio. You seem to have found hookup in the glove compartment. If you get stuck feel free to call my cell 724 374 3274 |
(Post 154565)
Ran in to issues with the top ( hydraulic pump ) and other major repair was fiberoptic repair on communication to CD player and Blue tooth. |
| All times are GMT -5. The time now is 02:00 AM. |
