-   Mercedes CLK Class (https://mercedesforum.com/forum/mercedes-clk-class-12/)
-   -   2004 CLK320 (M112) water pump replacement (https://mercedesforum.com/forum/mercedes-clk-class-12/2004-clk320-m112-water-pump-replacement-25663/)
MPHMERCEDES Dec 26, 2007 07:22 AM
The pully on my water pump seems to be running out of true so serpentine belt is catching the engine casting.
3 Questions.
1) How do I take the tension off the belt so I can remove it and investigate problem?
2) Is the water pump running out of true a common problem?
3) Are there any particular issues to be aware of when replacing the water pump?
Any help gratefully accepted, thank you
Mercedes whisperer Nov 16, 2019 03:48 PM
Well if you have to ask how to loosen the belt tension perhaps this is not a job for you. It may end up costing you much more if you mess things up.
