Noise at ignition! A Class
Having sorted out my air mass sensor problem - I thought I would ask about an irritating noise that occurs every time I start my A class - it only lasts around 10 seconds and sound like an intermittant 'pumping' noise coming from the dash!
any ideas guys? |
RE: Noise at ignition! A Class
Are there any dash lights on when this happens? Is it a fast ticking noise?
The SRS light has been on for some time - but the noise is not really a fast ticking - it is intermaiitant fo approx 10-15 seconds - sounding every 1-2 seconds if thats any help?
Hi Tracy,
Have you found out what was causing the noise? my wifes 2001 A190 80k miles started doing this last night. Basically it started when I switched on the air recyle button, so I am guessing its something to do with the pollen filter. On investigation it seems to be coming from underneath the off side wiper control arm, but I couldnt see any easy way of accessing that section without removing some of the body panels. Help will be greatly received as we have had the car since new and there are loads of things going wrong at the moment i.e. air mass filter issue front brake discs warping every 6 months with no obvious solution creaking noise when the sunroof is open driver window creaking as though it miss aligned paint and bodywork issues but even with all this my wife loves the car so didnt need another issueto add to the reason to trade list. cheers Dave |
