Crankshaft Sensor Mystery-Your thoughts, please
1 Attachment(s)
CL600 2001 110k
I've got a crank-but-won't-start issue. Only code being thrown is P0335. Just replaced the Crankshaft Position Sensor. Still won't start. Still throwing P0335. "Signal Implausible" Now guessing I've got a wiring issue. I've got a new wiring harness for the CPS. Will try that, next. What else am I missing? See the attached printout from my scanner (Foxwell 520) Thanks. |
If the sensor was replaced, I would look into a possible fuel or ignition issue. Retrace your steps to make sure everything was plugged back in properly when your replaced the CPS.
Will do.
