Wheel Spacers
RE: Wheel Spacers
they have the same.
RE: Wheel Spacers
we even rotate the wheels front to back every 10k km.
the spare wheel must fit front and rear too. but on your model, you might have different set of bolts for spare. |
RE: Wheel Spacers
RE: Wheel Spacers
i don't get what you mean of spacer.
you put it between the bolt and rim or between the rim and hub? |
RE: Wheel Spacers
Yes, if you use a spacer you'll need longer lug bolts. ie.. if the spacer is 5/16 you'll need lug bolts 5/16 longer than the ones you have. Personally I can't stand to run spacers on the front-end as they can cause front-end vibration etc... As far as wheel offsets go...... it sounds like you may have the wrong rims for your car. The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types. Zero Offset The hub mounting surface is even with the centerline of the wheel. Positive The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. Negative The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset. If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. hope this helps |
RE: Wheel Spacers
| All times are GMT -5. The time now is 04:10 AM. |
