W203 Cigarette Lighter Power Issue.
Just bought a 06 C230. Trying to use the cigarette lighter in front to charge my phone but it doesn't continuously give power. I tried charging my GPS unit also and I still get the same issue, it charges for a few seconds then stops. If I push the charger in and hold it in place it will charge.
Any idea's how to fix or what is causing issue? |
youll probably need to bend the tabs inside the lighter. make sure the key is off or youll blow the fuse. youll see 4 tabs, bend each one slightly in toward the inside of the lighter. 2 on the sides and 2 on the bottom use a small pocket screwdriver or an angled pick to bend them that should take care of your issue.
