Vacuum line help
1 Attachment(s)
I have a c220 mercedes benz and noticed that one of my vacuum lines was broken off. I have a picture of what seems to be a vacuum modulator from what I have read in other forums. I want to know where exactly the broken hose is suppose to go because there are two free holes where I can plug it in.
Anyone also know where I can get a link/picture or diagram of these hoses throughout the car? |
It looks like it would plug into the middle,just a guess
Thanks,just making sure. I am having a bit of trouble locating what seems to have been a cut rubber fitting that is underneath the window washer reservoir. Anyone have a clear picture of this area or can tell me where the line should go. There are two vacuum lines one of them is green the other looks black and they go horizontal, but the other on the tip i cut, have no idea where it goes.
yes you can get those broken off parts from the dealer. only problem is telling them what and where it is. if you can take one in for them to see maybe they can help you....look very carefully and closely at the other not broken lines and see if you see a part number on it.###-###-##-## sometimes they are stamped on there. that vacuum block usually has alot to with the climate control flaps and they do leak also and get fine hairline cracks
