srs light
Hey.
I just removed my instrument cluster from my 94 c280 to replace a bulb, and when i put it back in now the srs light comes on when i start the car and doesnt go out for about a minute or so then goes out, it used to come on then go off, but now it does what i just described. I read somewhere that i may need to clean my seatbelt plugs. any help appreciated. -Logan- |
RE: srs light
it should be 4s.
only by reading the fault code that you will know. |
RE: srs light
Al, Logan if you guys can look at my issue I've posted. I'am hoping you guys can be some quick guide on the cooling trouble. Thanks a lot in advance.........Al matulungan mo ko, salamat ulit.
RE: srs light
Thank you for reply sleepwkr.
Is there any way to simply reset the srs system, without dealer fees $$ as it was caused i beleive because i turned my car on while my dash was out. |
