Sleepwalker Help! AC problem
Old Mar 9, 2006 | 02:02 AM
fay3131's Avatar
Default Sleepwalker Help! AC problem
Ok, here we go. I have a 98 C280, the other day I noticed the AC wasn't as cold as it should be, so I had it filled and put some dye in to search for a leak later. About a week later the EC light came on and stayed on, and it is yet to go off. The air gets cool but not cold. I did a forum search and saw where you said it could be one of two sensors. However, is it possible that's it the compressor? I sent a private message to the person who had the same problem but I haven't gotten a response. Also if you could post any diagrams to help me with whatever problem you think it is, I would greatly appreciate it. Anyone else who has anything to offer please feel free everything helps.
Thanks,
FA
Old Mar 9, 2006 | 02:33 AM
sleepwalker's Avatar
Default RE: Sleepwalker Help! AC problem
first you must check if there is still a leak.
if the pressure is less than 6 bar with engine running and compressor "on"... then you need to find that leak and fix it.
if the pressure is more than 8 bar (engine running and compressor on), then one of the following sensors got problem (attached). most preferably the refrigirant sensor.
[IMG]local://upfiles/1/65ADFB09C2EF4B7C960E57B4FDA0ECCA.jpg[/IMG]
[IMG]local://upfiles/1/DBB2CBD222DC4654ABEE0FB01D5254A0.jpg[/IMG]
Old Mar 9, 2006 | 04:00 PM
fay3131's Avatar
You the man! I may need to ask some more questions, but hopefully this is it.
Old Mar 13, 2006 | 01:28 PM
evillwock's Avatar
Since ive owned my 97 C230, ive been having that exact same problem, depending on how hot it is outside. on a summer day when its 95, the A/C condensor/clutch turns on and off, randomly. When its dark and starting to get cooler out, the A/C blows Ice cold. I had the entire A/C system under the hood replaced, and the problem still occurs. The mechanic told me it was my in-dash control unit, but I think its these sensors you are refering to. Any ideas?
Old Mar 13, 2006 | 09:51 PM
you got sun sensor?
Old Mar 14, 2006 | 12:25 PM
evillwock's Avatar
I'm not sure what that is.
BenzoDJ
Apr 11, 2007 11:07 PM
edl100
Jan 16, 2006 03:08 AM
Shan
Aug 31, 2005 07:18 AM
hjtw
Jun 3, 2005 10:28 AM
Mawbs
Jun 2, 2005 08:07 AM
