service light indicator
Old Nov 29, 2006 | 06:05 PM
taff1949's Avatar
Default service light indicator
hi
can anyone till me if there is a way i can reset service light on a 203 series c class? the car has only done 3000miles since last service,it is showing service due on time not mileage.on the previous model it was possible to reset it manually,
thanks to anyone taking trouble to reply
Old Dec 4, 2006 | 11:54 PM
Polcha71's Avatar
Default RE: service light indicator
just because you havent' driven over 3000 miles doesn't mean your oil is still good. the molecule structure of your oil breaks down over time. the molecules spread further apart and no longer provide the correct lubrication and protection. get an oil change or the inside of your motor is going to pit.
Old Dec 5, 2006 | 06:01 PM
andyd987's Avatar
sleepwalker posted this last year.
try:
Turn the key to "on" (not start).
With the key in "on" position, push the trip meter reset button twice quickly,
the remaining miles to next service will appear.
hold down button, and with your other hand turn the ignition off, then back to "on"
again. KEEP holding that button down. It will take about 10 seconds
the new miles (KM) remaining will appear in the odometer
close the door while doing it.
link to discussion thread on this forum
https://mercedesforum.com/m_12133/tm.htm
if it has been a while it is probably a good idea to change your oil, although synthetics are better moisture can still be a problem
Old Dec 5, 2006 | 06:20 PM
andyd987's Avatar
The procedure is also listed on page 140 of the owners manaul for my 2002 Sportscoupe
Old Dec 5, 2006 | 07:52 PM
taff1949's Avatar
thanks andy
i will try it out.
homester
Sep 29, 2011 12:09 PM
sebringauto211
Feb 17, 2011 09:55 AM
acowan
Jul 12, 2009 08:03 AM
planetobagirl
May 3, 2009 11:31 AM
taff1949
Dec 5, 2006 03:04 PM
