-   -   Problem with locking system (https://mercedesforum.com/forum/mercedes-c-class-10/problem-locking-system-49823/)
Minsring Oct 28, 2011 12:37 AM
I have a problem locking my car using a remote control. I can only lock/unlock the driver sided with the remote, but the rest remain unlock. I have to manually push the lock knobs down to be able to lock my whole car. Also, my gas lid would not open sometimes.
Can anyone help me? I don't know what is wrong with my car. My car is 2000 C280.
Thank you in advance!!
chassis221 Oct 28, 2011 09:57 PM
check all fuses first.
Minsring Oct 29, 2011 03:36 AM
I did checked all the fuses...it is fine.
chassis221 Oct 29, 2011 09:43 AM
if your sure the fuses are fine, then now check your door jam switches, on the affected doors.
even when you use the interior switch, only the driver door works? if those are all fine, you could have a vacuum leak someplace. i still suspect a relay or fuse.check fuses in the trunk in front of the spare tire, there are some fuses there too.
Minsring Oct 30, 2011 12:31 PM
Ok I will do that
Thank you.
Unimog_01 Nov 2, 2011 09:36 AM
Ignition Tumbler
Can you help me out with my Lock issue? C220 1996
I have to replace my Tumbler( Key wont turn at all. Ordered a new Key, still no luck)
does the lower Dash separate from the upper? I have everything loose but am afraid to damage the plastic, I cant make out how it is connected.
thanks
C220 1996
