No Hazard, No Indicators, Elect mirror & reverse light fault
Hi, I have a 94 C280, good Mileage and very clean n tidy but am having problems I was warned about after I bought it.
Typical, they can be knowin it all untill you ask about remedies aye!!! The first problem existed when I got the car, that is the reverse light and Electric Mirrors are on the same fuse. When I fit a new fuse it blows the instant I turn the ignition on. The other is the Turn Indicators and hazard lights stopped working simultaneosly. I mean I pulled over to the side of the road one night and they never worked since, the Hazard lights stopped at the same time and the fuses are fine. I found a blown 15Amp fuse on a bright blue relay behind the fuse box and replaced it. it has neither blown since or made anything work. The Hazard light switch is illuminated so you can find it at night this light still goes dimmly but goes out when you move the switch to the on position. (I assume this is on the dash light circuit) Any help would be appreciated. P.S. I imported this car from Japan [IMG]local://upfiles/12628/9D998284C53A4263BCF02F59C6F0F9AA.jpg[/IMG] [IMG]local://upfiles/12628/4F72A0F1791B45DFAFD8ACB19FEDD99B.jpg[/IMG] |
