MB Engineers careless in units?
Most cars get it right on Tachometer labeling.
Correct labeling. Type(1): Numbers 1 2 3 4 5 6 7 on the dial with unit reading x1000 RPM. Type(2): Numbers 1 2 3 4 5 6 7 on the dial with unit reading x1000R/M. Wrong labeling. MB-VDO: Numbers 10 20 30 40 50 60 70 on the dial with unit reading x100 1/min. MB-VDO could admit to their poor mathematic skills and correct the mistake as follows: MB-VDO: Numbers 10 20 30 40 50 60 70 on the dial with unit reading x100/min. I don't know how many years MB & VDO have been making that mistake boldly. ...Are they still making that mistake on the newer models? Mine is 1999. |
RE: MB Engineers careless in units?
Your suggestion is mathematically correct, but not any more valid than the way MB expresses it...It's just a shorter version...Have you ever thought how many people out there may not know that when you're multiplying a fraction by an integer you should multiply an integer by the numerator with denominator remaining the same??? Maybe that's why MB left it in its simplest form?!
dxm8693 is your nose bleeding??? :)
Haven't the foggiest. But, bet those Germans have some rational.
| All times are GMT -5. The time now is 10:09 AM. |
