MAP sensor location
Can someone please help me locate the MAP sensor on my 2000 Mercedes Benz C230? I am getting a CEL and the code says check MAP sensor. I know where the MAF sensor is located but I now need to check the MAP sensor. I have looked all over and can not find it. I would be nice to have a picture or at least detailed specifics on location. THANK YOU!
On my 2006 C230 Kompressor its located just inside the screen when you remove the air filter..Its a little arm that hangs down.. Be careful to not mess with it, Very delicate ad very expensive if damaged...Go to Autozone and get a can of MAF sensor cleaner spray and try cleaning it..If you have a K and N air filter, the oil from the filter can foul the sensor and sometimes can ruin it...Thy cost around $800 to have the dealer replace it...
| All times are GMT -5. The time now is 03:57 AM. |
