Major Issue HELP!!
Old Dec 3, 2013 | 09:54 PM
Sneakerhead_808's Avatar
Default Major Issue HELP!!
I have a 1996 Mercedes C220 4 Cylinder and I think I'm having issues with the throttle body, I took it to AutoZone and the the code that came up. The car idles rough on park as the RPM is constantly fluctuating I changed the Mass Air Flow Meter today thinking it would fix the problem but it didn't, I want to change the throttle body tomorrow but I'm afraid it may not solve the problem. When on drive and i hit 300RPM's the car begins to jerk as if its chocking hesitating to go.
Can someone please help!!
Old Dec 4, 2013 | 05:34 PM
chassis221's Avatar
probably Not the throttle body. maybe you need a tune up? how is the engine wiring harness? if its cracked and brittle it can cause problems., Do you possibly have bad fuel? how old is the fuel filter?
Old Dec 5, 2013 | 08:09 AM
I figured it may not be the throttle body either I changed it a couple months ago due to this happening before although it stoping giving me these problem for a while until now... I changed the spark plugs in the summer but I don't mind doing it again when I do an oil change but the wiring on the harness is showing and look old and my mechanic is suspecting that might be the issue of the car Rough Idling , engine misfireing above 3000 rpms and I read up on the fuel harness fault symptoms and it seems as if that may be my problem.... Unfortunately to buy a new one is expensive so I will look around at a local junkyard for one in good condition
SVETTE
Jul 16, 2008 10:29 AM
RobertCMU
Jul 17, 2007 02:15 PM
bergfurher
Nov 3, 2006 12:09 AM
jclumnkis
Feb 26, 2005 07:55 PM
tiberius06
Feb 21, 2005 02:43 AM
