MAF & Sunroof Problem
Old Oct 20, 2008 | 04:05 PM
xlibe's Avatar
Default MAF & Sunroof Problem
1. I need to replace MAF sensor on my 2003 c230.
Where is the best place to order MAF?
Does it take only 2 torque screw to remove and replace the MAF?[&:]
2. The sunroof on the same vehicle is opening only partially - app. 1 inch at a time when I push the sunroof button.
This happened a few month ago but was working properly for another few month before this happened.
What is the exact problem?
Do I need to replace the motor for the sunroof or the whole sunroof?[X(]
I would appreciate much if anyone can answer any of the above questions.
Old Oct 24, 2008 | 09:49 AM
Solobinoy2k's Avatar
Default RE: MAF & Sunroof Problem
Oder the MAF from a reputable parts store, stay away from EBAy. Dealership is the safest bet if you can afford it.
You may need to re-synch your sunroof. It's in your manual how todo it.
Old Oct 24, 2008 | 11:10 AM
jreckseidler's Avatar
One thing it could be (and sometimes the simple answer is best): the rails may need to be regreased. I use my sunroof in my '06 C230 a lot and sometimes it will only close 1/2 way when I hit the switch. Each time I take the car to the dealer we make sure the rails are well lubed and it solves the problem immediately.
Take it for what it is....it could be more than that but its worth a look.
JR
Old Oct 24, 2008 | 12:01 PM
xlibe's Avatar
Thanks Solobinoy2k and jreckseidler.
I'll try what you guys have recommended this weekend and let you know next week.
You guys have a great weekend.
Fizoust
Nov 29, 2009 10:17 AM
CollectiveSoul
Feb 18, 2007 03:54 PM
BruceG
Jan 20, 2007 04:28 PM
ARMENDS500
Jan 28, 2006 01:17 AM
kaan
Nov 6, 2004 02:19 AM
