how make 230 faster
i have an 03 c230 sedan kopmpressor it does 0-60 in 8.5 seconds. is there any way to make it do it in less time without costing an arm and a leg ?
RE: how make 230 faster
get an ecu upgrade. it'll make it a tad faster.
If you would like to increase the speed of your car by
5 - 10% without buying any hop-up parts, try the following: 1. Use very light oil (e.g. WD-40) instead of grease to lubricate gears, bushings, or bearings. This will free up the transmission of the car. Note, some says that doing this may make the gears wear out faster, and mercedes c36 radiator to easily overheat but I personally have not noticed this. |
NOS!!!!Spray the house down!!!!!!!!!
But seriously, a 50-100hp shot shouldn't hurt. Best "BANG FOR THE BUCK"!!! |
:DI've only got 3-1 household oil - would that do the trick?
Free to good home if you need to do these mods [8D] ORIGINAL: kurtdaniel If you would like to increase the speed of your car by 5 - 10% without buying any hop-up parts, try the following: 1. Use very light oil (e.g. WD-40) instead of grease to lubricate gears, bushings, or bearings. This will free up the transmission of the car. Note, some says that doing this may make the gears wear out faster, and mercedes c36 radiator to easily overheat but I personally have not noticed this. |
| All times are GMT -5. The time now is 06:50 AM. |
