-   -   Help, Help, C320 Brake Problem!!!! (https://mercedesforum.com/forum/mercedes-c-class-10/help-help-c320-brake-problem-25471/)
no bad days Dec 16, 2007 07:31 PM
I have a 2001 Mercedes C320 and it recently started flashing the following error codes on the dash; ESP, BAS, ABS and then it said Brake Lining Wear Visit Workshop. The computer alsoretardsthe engine and the car only goes about 30 miles per hour when these error codes are flashing. This probelm is intermittent and sometimes I can drive 30 to 40 miles before it does it. Other times the error codes flash as soon as I start the car. I had the rear brakes replaced about six months ago and I thought that the front brakes may be causing the problem, therefore I just had the front pads and rotors replaced. The shop also replaced the front brake sensors as well. I then thought it may be the brake switch so I bought one from Walter's Mercedes and just replaced that too. The computer still flashes the ESP, BAS, ABS, Brake Lining Wear Visit Workshop Error Codes. Does anyone know what else the problem could be??? I am planning on taking the car into a local Mecedes Benz repair shop in the next few days, but would like to fix it myself if possible. We have a new baby and buying the formula food and diapers is killing me so I'm trying to save as much money as possible. Ten Thousand Thank You's!!!
no bad days Dec 16, 2007 10:30 PM
RE: Help, Help, C320 Brake Problem!!!!
Does anybody ever respond with answers on this website????
no bad days Dec 21, 2007 09:43 AM
Can anyone help me out with my brake problem? If not, does anyone know a good mechanic in the Upland, Ontario,Rancho Cucamonga CA area???
