Harsh downshifting during braking
Old Aug 6, 2006 | 04:14 PM
dv/dt's Avatar
Default Harsh downshifting during braking
I searched but could not find a topic on this.
Is this normal for mercedes automatics (or more specifically C230Ks)?
During normal stops, say up to a stoplight, the engine will downshift while you are braking.
You really feel it pulling the car at each shift making every stop jerky and annoying.
I've never experianced this on any other automatic.
So is this normal?
Old Aug 6, 2006 | 05:43 PM
rexde1's Avatar
Default RE: Harsh downshifting during braking
Mine does it to where you can feel it but I wouldnt say it is jerky. I read some posts that said you can reteach it but don't know anybdy who has tried it.
Old Aug 6, 2006 | 07:40 PM
RockSolid's Avatar
ORIGINAL: dv/dt
So is this normal?
Yes, it's normal. I understand that even newer MB transmissions have hard downships when decelerating at at slow speed.
I found after a transmission fluid change (when I changed MB's "fluid for life"-yea, right) the hard downships are far fewer and all shifts are better.
Old May 6, 2010 | 11:08 AM
chris1's Avatar
I have similar problem with C180. Also similar reaction when kickdown from 4th to 3rd
Old May 6, 2010 | 04:34 PM
chassis221's Avatar
could be the incorrect fluid level, a software flash from the dealer might help too.
Old May 7, 2010 | 02:42 AM
varuj11's Avatar
take it out of sport put it to w u wont fell it no more
Old May 9, 2010 | 03:11 PM
chris1's Avatar
It happens in w also though not as bad. Changed fluid and level is perfect but still no joy. Thanks for the quick responses.
Old May 18, 2010 | 11:42 PM
Mikhail Paremski's Avatar
I had similar problem with my 2007 c280. It was fixed at dealership. They told me, they have updated firmware.
Old May 19, 2010 | 10:19 AM
  #9
ontmiss's Avatar
Try ECU reset
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least four minutes for ECU to reset
Old May 25, 2010 | 07:33 AM
  #10
chris1's Avatar
Default ECU Reset
Had tried ECU reset. Helped with perforance but still have problem with down shift. Did this solve it for you?
SunDance1
Aug 28, 2014 09:48 PM
rover1
Oct 28, 2009 08:42 AM
asingreat
Sep 5, 2009 02:03 PM
burdman_260E
Feb 11, 2007 06:07 PM
DPerez320
K1 Motorsport
Feb 8, 2007 10:16 PM
