Fuel for my C230
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><FONT face=Garamond size=3>Are you using Premium grade fuel or Regular in your Mercedes?<SPAN style="mso-spacerun: yes"> </SPAN>I was surprised to also see that Premium is recommended. </FONT></P>
Fuel for my C230
Premium only. That's due to the way the vehicles ECM is programmed. On the other hand I do know some who have tried mid-grade with no ill effects.
Fuel for my C230
The Mercedes Dealer in my area advised me to run the low grade fuel through my car during the winter. Apparently, there is an additive which gums up the engine. Has anyone else heard anything similar?
Fuel for my C230
The octane number we see at fuel pumps in the U.S. are the average of Research Octane Number(RON) and Motor Octane Number, (RON + MON) / 2. But the rest of the worldgradesgasoline byRON only. </P> The number we see at the pump is also known asthe "Anti-Knock Index"; the number shows how well it prevents engine knocks. So it is never a good idea to downgrade what the manufacturer recommends.Although moderns vehicles are equipped with devices that are smart enough to "live with" whater its owners adds into the tank. But these devices were installed as "safety devices", not a device that help buyers to save money at the gas pump. </P> All gasolines sold in the U.S. are required by law, to have additives that cleans the fuel injectors, carbon build up..etc.. like 76's Pro Power, Chevron's Techron ...</P> |
Fuel for my C230
dont be cheap, burn the good stuff in the good stuff...just my opinion
Fuel for my C230
For anyone with a supercharged, Kompressor, engine, Premium fuel is a must with an Octane Rating ((R+M)/2) of 91 or higher.The fuel is less likely to prematurely ignite under the higher compression levels. It's also a good idea to use premium fuel for better efficiency and a cleaner engine. </P> |
