Front Left Side Marker Lamp.. Needs to be replaced.. lil help plz!
yup the side left front lamp went out... dang lights always go out. well anyways this is what it says on the dashboard Front Left Side Marker is out which is the yellow light for the left turn signal i belive.... ok well it cost 5 bucks for the buld and 30 bucks to get installed from the dealer ship and im thinking of replacing it myself to save 30 bucks.. i just need help with one thing.. i know that you slide off the plastic light covor some how.. ive tried it but failed.. there is a certain way to take it off and i cant do it right... could someone please help me with this thanks alot
RE: Front Left Side Marker Lamp.. Needs to be replaced.. lil help plz!
Bang on it with your hand....Most of the time it isnt a bad bulb, just a bad connection....Use a wedge and pry it out....I cant remember but I think you pry it out from the front......or it could be the back..
thanks ill try prying it tomorrow with a flat headed screw driver and ill let everyone know if it works or not
yeah you getta pry it out from the front part of the car.. got it replaced, took me 5 minutes to installand the bulbs were less than 5 bucks haha thanks for the help
I was wondering if there was any other tricks to prying the side marker out, I too tried with a screw driver, but it won't budge. Plus the screwdriver is scratching the car a little too much, any advice?
try using a hard peice of plastic like the one u use 2 do tint or bondo. never use a screw driver on paint.
