ESP - Electronic Stability Program Not Found & Solution
I was searching the forum and didnt really find the solution for a while. Anyway I did some MAF work and spark plugs / oil change. 4 hours with the battery unplugged when I started the car my Check Engine light was out, but I had a Malfunction of ESP - Electronic Stability Program Not found. I finally found the solution to this is start the car. Turn the steering wheel full left, then full right, then full left, and turn the engine off. This reprograms the ESP and turns off the malfunction.
I hope this helps someone in the future. NeV |
RE: ESP - Electronic Stability Program Not Found & Solution
was posted here a few times before. sometimes "search" function can also help.
thank you for the tips. |
