Engine Oil
Old May 4, 2006 | 03:08 PM
rohitsagar's Avatar
Default Engine Oil
After How many miles do we need to change Engine oil.
Mercedes C 240
2002
Another thing - It gives a message , Break Lining Wear - Visit Workshop. How much would it cost to fix it in IL - USA ?
Any ideas ? []
Thanks in advance
regards
Old May 4, 2006 | 06:57 PM
no_mo_bmw's Avatar
Default RE: Engine Oil
It is telling you your pads are worn to the sensor. No one can guess what this will cost you. You will need new pads, likely new rotors and some fluid. If you are lucky your Calipers will be fine, after all the car is only 4 years old. While I am new to MBZ's judging from what I know having had several BMW's you should expect to pay about $400-$600 for the brakes per axle to have a good shop do the work.
Old May 6, 2006 | 01:58 AM
fly_major_fly's Avatar
I dont know much about beamers, but from what i've heard from owners....
bmw-usa requires new rotors when brake pads are worn out.
someone with credentials, please deny it, or affirm this.
Old May 6, 2006 | 02:54 AM
fay3131's Avatar
Yes, BMW doesn't recommend turning rotors and neither does MB.
Old May 6, 2006 | 06:27 PM
97dmsrS420's Avatar
Normally, a set of rotors will allow pads to be changed twice. The rotors are composite rotors that wear with the pads. However, I have heard that some people have allow the shade-trees to turn their rotors. I would never allow my rotors to be turned (provided I know about it).
As for oil, well, I live in NC. I use Mobil 1 (15W40), year round. And my cars do well.
Old May 6, 2006 | 06:29 PM
97dmsrS420's Avatar
I change mine every 3500 miles.
floresadolfo1
Jan 26, 2007 04:15 PM
drblank
Jan 9, 2007 10:33 PM
RockSolid
Jun 24, 2006 06:41 PM
BenzoDJ
Mar 13, 2006 01:14 AM
mbrown400
Apr 3, 2004 02:42 AM
