Engine light on
Hi, I have a 1997 C 280. Recently the engine light has gone on. I know this has something to do with the pollution control. I had it checked out and the mechanic said that the gas cap may not be creating a sufficient seal. He suggested that I buy a new gas cap. He reset the light and it stayed off for a couple of days but it is now on again.
Has anyone had this happen. The car is running great. It doesn't seem like there is any problem. Thanks Karen |
RE: Engine light on
Bad oxygen sensor. Any Benz mechanic knows it. You must have talked to a gas station mechanic.
Read OBD2 code and it will tell you which O2 sensor has gone bad. Your car I6 or V6? (V6s have 4 O2 sensors. Left and Right, Before and After.) |
RE: Engine light on
Thanks...I will have it checked out. My car is a V6
RE: Engine light on
ORIGINAL: fly_major_fly Bad oxygen sensor. Any Benz mechanic knows it. You must have talked to a gas station mechanic. Read OBD2 code and it will tell you which O2 sensor has gone bad. Your car I6 or V6? (V6s have 4 O2 sensors. Left and Right, Before and After.) |
| All times are GMT -5. The time now is 10:37 AM. |
