Driver's window won't raise
I have a 1996 C class on which the driver's window won't raise. No current goes to the motor when I push the button to raise it. As a matter of fact, no current goes to the relay in the conveniece control module located in the trunk when I push the button to raise the driver's window. I removed the switches from the console and cleaned them the tested the switch and it is good. I have checked the fuse for front window raising and it is good. Current does go to the motor when I push the down side of the button and the motor works fine. The passenger window goes up and down just fine. This problem has stumped me... Help!
ifthecar
05-12-2013 02:07 PM
