Coolant Indicator ON-notice leak
2 weeks ago my 1995 C220 Coolant Indiactor came ON, I check the plastic coolant tank (the level) is low. I waited for the engine to cool after a few hrs, then I top up with water. 4 days ago, the indicator cam ON again. I decided to check the base of the engine, where there is the plastic base, I notice slight liquid with green colour coolant. I think this confirms a small leak somewhere. I notice the leak may not be from the radiator but below the engine. You notice on the photo I have remove the fan blade to get a better view of where the leak is. It look like from the hose connected below the engine. Can any one pls help me to diagnose. Kind Regard [IMG]local://upfiles/10129/3D8ED580370949719B63FFE9D9738B93.jpg[/IMG] [IMG]local://upfiles/10129/7B70127EE42848C486FF1BE3115FA4A0.jpg[/IMG] |
Engine Mounts Broken
The mechanic have now replaced the Water Pump & new Radiator. Question is theRadiator look new from inside the engine bay but externally, where the 2 fans connected is still same. Is that the Air Conditioner/Heater Radiator? Also mechanic spotted that the engine mount is broken. I know one mount already replace last Aug, coz when car put on reverse it vibrate tremondously, so only 1 mount replace is that the left or right mount. Now this mechanic say "Engine mounts broken". Is it that he observed one broken mount & concluded/assumed the "plural". Whats will occur if that one mount is not replaced? Kind Regards |
