Check Engine Light
Old Jan 24, 2004 | 07:22 PM
iron pyrite's Avatar
Default Check Engine Light
I purchased a 1998 C230 approximately 4 months ago (42,000) miles and love the car. The cat seems to run hot (no check engine light)as when I turnthe caroff after going up a gentle grade to my house, it crenkles and crackles a lot. Our other cars (a '96, and '03) don't make a sound. I took it to the dealer and $100.00 later they said no problem. Two weeks later the check engine light came on (code P0170) and I took it back. This time they said air massflow sensor requires replacement. I had overheard the technician talking to the service manager and from the content and the tone of the conversation, I question if it requires replacement. The technician had said something about 'the tail end of the pattern on the screen was slightly out of spec..........'. Because they didn't have a sensor in stock, I didn't leave the car. Is there an easy way to test the sensor without specialized equipment? Also can I just buy a new sensor and put it in and not have to 're-calibrate' the car?</P>
The car runs very well and gets very good milage - approximately 32 miles per gallon on secondary roads with little traffic. (Maybe too good of milage)</P>
Any comments will be greatly welcomed! </P>
Fred</P>
</P>
Old Jan 25, 2004 | 11:24 PM
C23098Peter's Avatar
My C230 98 has 120K Km and my "check engine light" has been on for approx 10K Km. They say it is the mass air flow sensor too but I am not changing it yet. They say it is a common problem... It sounds like "microsoft known issues". Anyway, if anybody has a cure (other than changing the MAFS every now and then), please post a reply.
</P>
Old Jan 26, 2004 | 09:24 PM
<FONT face="Times New Roman">
My car seems to be running lean - the cat is getting hot and the milage is aroung 32MPG so rather then risk damaging the valves (and mortgaging my house to pay for it), I’m going to replace mine shortly. The cheapest that I could find was $320.00 (Bosch part) from 1-888-467-7278 (I forget the name of the company). They said it is easy to install and no further ‘calibrations’ are needed. This is much cheaper then MB service. </P></FONT>
Old Jan 16, 2008 | 04:01 AM
djnevoc's Avatar
Default RE: Check Engine Light
I got a re-Man for $180 let me know if you want to get one. Advance auto orders them and only a $30 Core Charge.
Old Jan 16, 2008 | 09:09 AM
Avid Edit's Avatar
Get yourself some CRC Mas Air cleaner.
Torx 20 security bit
Remove sensor from MAF Body
Spray it down, do NOT touch the wires
Easy removal and replace.
$6.00
Old Jan 16, 2008 | 03:10 PM
maherov's Avatar
I have had to change the air flow sensor before, no calibration was needed, just remove the old one and plug in the new one
Old Feb 21, 2008 | 10:18 AM
platonmind's Avatar
My C 230 from 1998 has 90K. Last year I changed AIR MASS FLOW SENSOR / $ 400,oo for new part /. It took me 1/2 hour to do it. Easy job. For the folks who don't know, PO17O mean you need to replace AIR
MASS FLOW SENSOR and I better like new part than to clean old one.
nolen01
May 7, 2015 05:58 PM
solarant
Dec 27, 2007 11:34 AM
krisgt2@hotmail.com
Sep 28, 2007 01:41 AM
