Changing Brake Pads
I am having trouble changing the front brake pads on my 2006 C230. does anyone have any directions on how to do so?
RE: Changing Brake Pads
you can search on this forum. maybe it will help: https://mercedesforum.com/m_53624/mpage_1/key_/tm.htm
good luck and welcome to the forum. |
Hello I have a 2002 C230k and changed all mine, They are pretty basic, No Directions just remove the wheel, Unbolt the caliper that holds the pads, they will be on there pretty good,may need to knock them out. Get a good size Cresent wrench and squeeze the ring back so that you can put both pads in on each side and that it will fit over the disk, Do not get your pads from Autozone or where ever, they will squeel and produce alot of black carbon. I purchased ceramic racing pads from a suplier ebay, they are going strong over two years. You may have to drill a hole for your sensors to fit in, just look at your old ones when you get them off and note the location of the holes.
