C350 2008 shimming / loose Steering Wheel
Hello,
I have a Mercedes C350 2008 Chasis W204.056 The steering wheel is shimming and it feels loose. I check and the noise is comming from the rack n pinion. Is possible to adjust the rack n pinion (steering box) with the screw that has on the side to eliminate the play in the steering wheel? :confused: I want to know that before I order a replacement. In case that the rack is bad and I need to buy a new one. Should I go with used with warranty or rebuild OEM? |
