C320 Battery Drainage
Hi. First time here and i'm trying to help my mother. Someone broke intio her car two weeks ago and stole her GPS. They smashed the small window on the drivers side, passenger window. Since then the battery keeps draining and it requires a jump start to start the car. She took it in and the dealer checked the battery and alternator and found that something is draining it (duh), but not sure what it could be. I saw that a few people found that the "seat adjustment control module", seems to be the most common culprit. Is there a way that I can check this out before sending it off to the Benz dealer to be charged $$$$$$ to fix this? Could I fix it?
The window has been repaired since. The battery also was fine for three days after it was tested and put back in. That Saturday morning, it would not work again. I also remember that the alarm indicator is blinking as soon as she turns off the car. I thought it should only arm once your out of the car and have armed it with the remote lock.
Umm...We should find an expert on this issue. I have exactly same issue with you about battery drainage.I had a warning message on trip computer for alternator and battery problem. Igot the car replaced alternator and battery. And same thing happened next day. The funny thing is all these repair was done due to sensor error which read 203?. But now has new sensor, new alter and new battery. but has still battery drainage issue.
Now the car is stored in the shop. The mechanic tested the drainage issue and found 2 major sources. One is the commander unit and the other one is might be the pwr seats. The commander unit alone loses 2Amp. They said it's huge comparing to other cars which lose .5~.7 amp.Those sources are fcoming from actory installed OEM parts.
Is there anyone who would help us?
Had similar problem 1 year ago.
Had no idea were it drains, replaced the battery, drained... It was my last straw.
Went to the stealership.
After 12 hours they gave me a call : "Sorry it took so long to find a drain...... but we found it....it's front passenger seat control..... 2 hours of drain reseacrh = $250. Total you are looking at $800 including labor and a unit. Of course we can put a jumper on front seat but you will not be able to move the seat...."
That's a story.
In you case I would go to the dealearship. They shouldn't charge you for more than 2 hours of work (approx $250 last year) plus parts.
That's a story.
Just a suggestion. If you think it may be the power seat control modules. Unplug the modules (driver & passenger) for a few days and see if the battery drains. Ifthe battery is fine, connect one of the seat modules and leave it for a few days to see if it may be that particular one. If not, do the same to the other module.
Why pay the dealership $$$. Good luck, hope you find the problem.
Haha, dealerships of all brands look for way to stick it to you, it's just the way things are. My Ford dealer wanted $900 to do pads on my daughter's V6 Mustang. Not that I would take it there but I asked, is that for genuine Ford pads, they said no, that's $100 extra. Mercedes are no more expensive to fix than any other car if you take it to the dealer.
ORIGINAL: raceral
Funny you should ask.. Just got the wife car out of the Benz shop today for that exact thing.138 bucks for a "draw test".. 276 for the modul, 92 bucks for a test after they put the thing in. And then 300 bucks for labor.. Never agin will I buy one of these so called upscale cars...
hey my car is in the shop for the 2 time for the seat module. i thought it was the battery and even bought a new battery but i call my shop and he told me he has other cars with the same problem and it was good for me becuase they knew what it was to the didn't have to do all thses test.
if i was you i would just go and get someone to fix it. they cost to much if it gets messed up
