C280 Powerseat not moving
Old Apr 10, 2005 | 07:02 PM
fly_major_fly's Avatar
Default C280 Powerseat not moving
The power seats of my 1999 C280
- will move after ten minutes of driving;
- will NOT move immediately after engine start; and
- will move after going over a big bump.
Both driver and passenger side behave exactly the same (move or not move) at any given time.
Wiring - Checked. Perfect like new visually.
Fuse Box - Checked front & back. Nothing blown.
Jiggled wires - No Difference.
All moving power seats will fail immediately when the engine is turned off. They won't work for a good ten minutes even the key is turned back on (any position) immediately.
Could this be a RELAY problem? A computer problem? Or somethingelse? A known issue or I am the first victim?
Thanks,
A.
Old Apr 10, 2005 | 10:38 PM
sleepwalker's Avatar
Default RE: C280 Powerseat not moving
sounds like a rear SAM.
Old Apr 10, 2005 | 11:00 PM
What is a SAM?
I just replaced the relay module by the fuse box in the trunk. $40 and cures no problem.
Old Apr 10, 2005 | 11:57 PM
yes, that one.
what is your VIN?
Old Apr 11, 2005 | 02:19 AM
WDBHA29G3XA669846
Old Apr 11, 2005 | 04:42 PM
mikdade's Avatar
Seems like a loose connection somewhere. Shake down the wiring (again) while an assistant holds the switches, one at a time. If none of the motors works in either seat then it is a component or wire that is common to the entire system.
Check ground connections:
A7 - in trunk rt side, beneath large cover and near relays.
W18 - under drivers seat.
W19 - under pass seat near door sill.
Check relay K24 (convenience relay module) - rt side of trunk.
check module A37 (PSE control module) - rt side of trunk.
Also, it looks like a bad door switch could effect the system?
Old Apr 17, 2005 | 01:49 AM
Not a bad door switch because cabin lights responds fine to door status.
Which one is K24 and which one is A37?
I have recently replaced the one located left to the trunk fuse box.
Thanks.
A
Old Oct 16, 2007 | 05:11 PM
eusgrca's Avatar
My 99 c280 just started doing the same thing. The power seats work sometimes and sometimes they don't. Did you ever find out what was wrong and how to fix?
Old Oct 16, 2007 | 07:03 PM
  #9
trev0006's Avatar
Banned
loose connection most likely, check all conections under the seat and if you can use some electrical contact cleaner fro electronic store to clean the connections.
Old Oct 19, 2007 | 11:45 PM
  #10
tlingwood's Avatar
Yes, Indeed our 1998 C280 has had this identical issue for some time. Any update on this?
