c280 Instrument /Wood Panel Removal
I need to remove the wood panel to replace the Hazard light switch. I can't seem to get it loose and I'm wondering if there are special tools needed or if there is a special technique.
Pic attached courtesy of Boomin' benz (thanks!) [IMG]local://upfiles/12758/C7D0D07716BD42D68DF669C9BF2ED080.gif[/IMG] |
RE: c280 Instrument /Wood Panel Removal
I had to take out the panel by the stick shift and I used an old credit card to move it up and down while pushing to find those clips. I also had to pull the panel as I did this and I was able to unloose all the clips and the panel came off. I THINK this should be the case with your panel. Hope it helps.
removing center console
[IMG]local://upfiles/1/8FE76412EF754B95940EC496F27A7BAC.jpg[/IMG] [IMG]local://upfiles/1/2EB95338FC82487CB1C38B540F7A76EA.jpg[/IMG] |
removing cover at gearshift lever
[IMG]local://upfiles/1/18D2AC8112CA40AD9106B4C7EF1B6206.jpg[/IMG] [IMG]local://upfiles/1/B9BF18274A8347768DCE92FFFED2BE0E.jpg[/IMG] |
Enjoy
[IMG]local://upfiles/8874/F6CCFC4E5357444EAE5376BD617C5648.gif[/IMG] |
Hi, I am new to this forum and was wondering why I might not be able to view the file you posted. I am trying to remove the wooden cover of center console to replace trunk lid switch. Thanks guys!
