C280: backup lights not working
on our 1997 MB C280. Checked all the bulbs and fuses but all are fine. Is there anything else I should check?
RE: C280: backup lights not working
trace the signal from transmission range recognition switch or exterior lamp monitoring module or starter lockout / backup lamp switch or lower control field control module.
stating your VIN can make it easier for me to tell you directly for i have to know the system your car uses. |
ORIGINAL: sleepwalker trace the signal from transmission range recognition switch or exterior lamp monitoring module or starter lockout / backup lamp switch or lower control field control module. stating your VIN can make it easier for me to tell you directly for i have to know the system your car uses. WDBHA28E3VF551182 - Thanks for checking which part I should check next. |
