C230 battery/alternator light
Hello guys i have 2004 C230 with a brand new battery that once a day "just once a day" it turns battery/alternator light, when i check to see if alternator is charging it reads around 14v but if i turn the car off the light will go off until the next day or so , any ideas about this before i replace alternator ????? thanks george
RE: C230 battery/alternator light
i had a similar proble 2 times the firsta time my voltage regulator was damage the second time a cable from the alternator was going to ground doe to a bad cable
is the voltage regulator inside the alternator or is it outise like the old fords ?
in my 02 c230 is located inside the alternator
| All times are GMT -5. The time now is 03:51 AM. |
