C230 (03) Brake Pad Warning
Good day everyone. I just changed my oil and filter etc and in returning from test drive, Brake Pad warning appeared in message centre. Only came on once and not again. No indication if front or rear, that would have been helpful, however, in your experience since I have not touched disc pads yet I would be leaning towards front pads rather than rear.
In my other vehicles the front padsalways wear out first. Does this situation match your experience.
Any comments would be helpful.
Cheers,
Tryg
Cheers,
Tryg
That is correct, the front brakes do wear quicker then the back. The front brakes perform 60-70 percent of the braking force, due to the shift in weight when braking. That is why the front rotors are usually bigger then the rears.
Your front Mercedes Benz brake pad may be thinned and your sensor noticed it.The front brakes perform 60-70 percent of the braking force, because of the shift in weight when braking that is why it wears first.
PelicanParts.com
Jul 25, 2013 12:22 PM
John Hubertz
Mar 7, 2010 06:46 PM
stevey88
Mar 18, 2007 05:19 PM
