| g60go |
May 5, 2010 05:49 AM |
C220 D fuel leak from pump
Hi all,ive got a problem on my dads merc,he noticed a fuel leak yesterday,i couldnt see where it was coming from so today i put it on the lift at work and looked from underneath,it seems to be coming from the side of the inj pump,i removed the inlet manifold to have a better look but now i cant run it to see,before i removed it i ran it and had a look and i could see it running down the side of the pump,its almost like its leaking from where the two halves of the pump housing are bolted together!Does this make sense or has anyone heard of a similar problem? And how can it be fixed as its leaking quite a lot! Thanks.
