C200 kompressor stuck in gear 2004
Hi guys wondering if someone could shed some light on the problem I am having with my MB.
After 7 months of faultless driving my c200 has developed a gearbox fault. When I engage drive it no longer goes into 1 it now is blank and will not move up the gears. It will select reverse but jolts quite bad. Unsure if it makes a difference but there is a space saver on driver side rear. Could anyone advise what the problem is and possible fix? I have tried the YouTube reset the gearbox guide with no success. Thanks for your help in advance. Chris |
Lots of views but no replies?
Hello - have you tried pulling the codes off the DTC? This will likely give you a definitive answer to where the issue is.
Originally Posted by Dub_mk3
(Post 173583)
