brakes
i own a 05 c230 kompressor and i had my rotors and brake pads replaced at around 14000 miles which i thought was really early especially for rotors. 10000 miles later, the brakes are not smooth at all and they make weird noises. is it jus my brakes or does everyone seem to have the same problem?
RE: brakes
Did you discuss with the Mechanic why the rotors only lasted 14k miles? Did he give you a percentage on your pad wear or just tell you they need replacing? Were the rotors so bad they could not be "turned" at only 14k miles? Were the rotors warped? Do you really have a bad caliper that is warping your rotors?
All of this is weird at 14k miles. -Eric |
