BI-XENON VS. H.I.D.????????
Old Mar 21, 2006 | 07:56 PM
vhino's Avatar
Default BI-XENON VS. H.I.D.????????
Can anyone tell me the difference between these two. I've read some of the topics already and i'm still kinda confuse about it. I have an 2003 C240. I would like to intall an new headlight assembly with projector and probably get an HID, but i don't know if I already have an HID in it or BI-Xenon is already HID? Can someone give me an idea if i should just replace the bulb that will make it look BLUISH color like HID or better idea? Also if there's going to be a probelm with the computer on the car if i put HID in it? I would appreciate your response. I'm newbee and i don't know what im saying. LOL
Old Mar 21, 2006 | 09:05 PM
fly_major_fly's Avatar
Default RE: BI-XENON VS. H.I.D.????????
ORIGINAL: vhino
How can you not know? If you have real white light, you have HID. If you have real white light on both low beam and high beam, you have Bi-Xenon.
HID Xenon lights have a bit sophisticated moving mechanism. One such thing is the shutter. When you turn the lights on, you will ALWAYS see the light RISING.
If you cannot tell by the color...at least you should be able to tell from the movement.
Old Mar 21, 2006 | 09:09 PM
K1MOTORSPORT's Avatar
You can check by going through paperwork of your vehicle purchase or posting a photo of your headlights while turned on and we can identify for you. Assuming you have halogen bulbs, there are 3 options available.
1) OEM bi-xenons
2) DEPO clear projector headlamps with aftermarket HID kit
3) Aftermarket HID kit
Since you wanted projector look, option #2 would be the reasonable way to go.
Old Mar 22, 2006 | 05:37 AM
vhino's Avatar
#2 DEPO clear projector headlamps with aftermarket HID kit
I've already bought one pair from ProCarparts and I don't know if that has an HID kit in it. If it doesn't , can i use my old kit from the stock one or I have to buy the entire HID kit separately? Here I attached the picture and hopefully this would help a bit. Will this affect my computer from the car if I swap it? I assumed it will not but I don't really know. I would really appreciate your respond
Old Mar 22, 2006 | 12:15 PM
Attached image doesn't have HID unless specified when you purchased.
What do you mean by old kit from the stock?
If you have stock xenon, you can just swap headlight assemblies.
Old Mar 22, 2006 | 03:00 PM
vhino's Avatar
You mean, I could just swap headlight assembly without any problem by just replacing a different bulb right? On my manual it say that I have a bi-xenon h7 (55w) d2s-35, but i want a bluish color or that 8000k, how much do they cost and where can i find them. Can i just buy them at carparts store or special order? Thanks again, sorry i feel like an *** now
Old Mar 22, 2006 | 06:27 PM
If you have factory xenon, then you will need PIAA D2S bulbs to make even brighter.
If you have halogens, you can go with PIAA Xtreme white bulbs for bright look.
But you need to make sure if you have halogens or not first.
Old Mar 23, 2006 | 06:04 AM
vhino's Avatar
K1MOTORSPORT,
YOu are really a big help and I appreaciate every respond I got from you. YOu too fly_major_fly
Old Mar 23, 2006 | 12:27 PM
  #9
Not a problem vhino.
Old Mar 29, 2006 | 08:05 PM
  #10
vhino's Avatar
hey K1motorsports,
I have already installed my new headlight assembly and I found out that i only have h7 halogen bulb on them. If have to buy HID kits for it, is it going to be plug and play or i have to do small customize on it. I would really like HID on this. If you know someone that done this, or someone that knows how to do it let me know please!!!
