-   -   battery problem, trunk problem and more! please help! (https://mercedesforum.com/forum/mercedes-c-class-10/battery-problem-trunk-problem-more-please-help-21122/)
rameets Jun 19, 2007 10:52 PM
hello, i've seemed to have bad luck with the car lately, I have a C230 Kompressor 2000, my air flow sensor was not working so I changed it, and even then the car was jerking and not driving properly, so I disconnected the battery and closed the trunk. Now I can't open the trunk! Any ideas on how I can get it open? Or IF I can jump start the car, how can I do this under the hood? I don't want to plug it somewhere where I'll fry something. Really appreciate everyones help!
Thanks!
sleepwalker Jun 19, 2007 10:57 PM
RE: battery problem, trunk problem and more! please help!
use the mechanical key to open the trunk.
rameets Jun 19, 2007 11:02 PM
thats the problem the key wont fit in there it's as if the locks jammed or broken! lol I'm on a role with bad luck and now I just realized I may not have the radio code card either!
Shan Jun 20, 2007 02:43 AM
There should be a small red plastic cover somewhere close to where the battery -ve trminal is bolted to the chassis. A plastic clip holds the cover in position.Open it and the metal piece visible(sometimes labelled 12 V) is the +ve terminal for the jumper battery. Use any suitable point on the chassis as -ve forthe jumper battery.
Good luck.
SHAN
