97-C280 Headlight Replacement
How hard is it to replace the low beam headlight on a 97 C280?
Should be pretty easy. Do you have your owner's manual? It's in there I'm sure. Should be accessible from under the hood behind the lamp itself if it's like most of them. There will be something that will twist to "unlock" and then the bulb can be replaced.
| All times are GMT -5. The time now is 08:46 AM. |
