2010 C300 Sport 4MATIC - Driveline Vibration
Old Dec 18, 2015 | 01:28 PM
Doug Simmons's Avatar
Question 2010 C300 Sport 4MATIC - Driveline Vibration
I recently started to notice a vibration (I believe in the front driveline) when I am going up an incline and accelerating... I can accelerate on level or downhill, and I don't seem to notice anything, however when I am on an incline and accelerate, there is a very noticeable vibration (again I believe in the front end). Any help diagnosing would be appreciated!!
Old Dec 19, 2015 | 10:09 AM
Thanks... I'm assuming that's not easily determined unless there's something actually loose or cracked though...
Originally Posted by ForcedInduction
Check your engine and transmission mounts.
Old Dec 26, 2015 | 08:11 AM
From what we could tell, there seems to be very little movement, although i'm not sure how much there should be. My son and I think that perhaps a driveshaft flex joint could be going bad...any thoughts on if my symptoms could be pointing to that? Is there any way to verify if those are bad, other than something visually be wrong with them? Thanks!
The easiest way to check mounts is to have an assistant do a transmission stall test while you watch for movement from the mounts.
keh6444
Jun 24, 2019 04:05 PM
Mike Nakhla
Mar 15, 2015 07:44 PM
RBK
Mar 17, 2013 09:03 AM
trev0006
Jun 10, 2009 08:54 PM
