2007 C230 Rear Door Question
Old Jan 20, 2007 | 12:11 PM
rantonio's Avatar
Default 2007 C230 Rear Door Question
Hi all,
Just got my new 2007 C230. The manual says the rear door should open from the inside, even when the car is locked. The owner's manual explains that the door handle is pulled once to unlock the door, and then a second time to open the door (much like my old volksie). I have found that the door can never be opened unless the car is unlocked. It is almost as if there is a "child safety" feature engaged. Can anyone offer some guidance?
Thanks!
.rob.
Old Feb 7, 2007 | 11:57 PM
Surfahdude's Avatar
Default RE: 2007 C230 Rear Door Question
Uh yes, there is a Child Safety device on the driver side door right below the power window buttons. Make sure it's in the off (clear circle) position. If you see a solid circle (filled in white) shift the lever to the right to unlock.
Old Feb 8, 2007 | 08:32 AM
Shan's Avatar
All doors can be opened from the inside.
If you want the rear doors not to be opened from the inside at all times, then you will have to enggage the chikd safety lock. It is a little gadget you will see below the door lock when the door is open. Then the rear doors can only be opened from the outside when they are not locked.
Shan
miamilakesmb
Aug 1, 2011 10:40 PM
nm2010
Mar 23, 2010 11:36 PM
Pilsen
Feb 13, 2009 05:08 AM
Borisn23
Jan 20, 2008 12:22 AM
geno1
May 23, 2007 03:17 PM
