2006 C230 Fuse #53 keeps blowing and car won't crank/start
this car is really giving me hell lol, I first thought it was the starter then I jumped it direct and it cranks just not with the key, checked all fuses in SAM module front and rear and all are good except front SAM fuse 53 was blown, replaced it and when I turn ignition on it blows the fuse. I put a test light to it, end to positive and tip of light to fuse and seems to be grounded out somewhere, I'm stumped on this one, any help would be great help..
Hi Sam and welcome to the forum! Before spending any money on parts; have the codes read to see where the issue is coming from.
have same problem
Everytime I turn ignition to position 2 fuse blows 25amp fuse. Lost not sure which way to go car is a 2006 C350 sport. Maybe front Sam unit? Anyone with past knowledge help would be appreciated, very desperate at this point. Can't communicate with ecu for fault codes.
Originally Posted by Sam Omar
(Post 173840)
Burnt ECU
Easy fix, remove ECU and have it tested. Buy used ECU exact numbers (eBay). Have eBay ECU programmed to your car. Totally cost around $500.00. I will help you with this if you need it. Plug and play, back on the road like new again. |
Has anyone confirmed a fix on this I have 07 c230 same issue blows fuse 53 as soon as I turn key to on position I’ve checked wiring all looks ok I’m leaning towards ecm smells burnt also
2006 slk350 70,000mi. Also fuse blows & no crank
Originally Posted by Caraujo
(Post 181321)
