2003 C240 Alarm System Battery
Old Feb 21, 2010 | 05:37 AM
inkpusher's Avatar
Default 2003 C240 Alarm System Battery
I was told that the issue I have with the alarm going off randomly could be from a weak secondary battery. I'm told that there is a high voltage battery that is located some where in the vehicle, but I can't locate it. Does anyone know where it is?
Old Feb 27, 2010 | 09:50 AM
MB-TECH-38's Avatar
Default Second car battery
Your car does not have a second car battery. You have an alarm problem, it could be as simple as a broken door switch and the alarm thinks its open when closed
jerry
Old Feb 28, 2010 | 06:08 AM
inkpusher's Avatar
Default Much Appreciated
Thanks. I will follow up on this.
Old Feb 28, 2010 | 03:17 PM
sleepy_b's Avatar
I had a few that the key was actually causing the alarm to go of intermitantly. Found it by accident. I pulled the key apart to inspect the batteries and when I put the key together the alarm would go off immediatly. I noticed that if I locked the car and left the key in range the alarm would eventually go off. If I locked the car and took the key out of range it never went off. Replaced the key and never had a problem since. Not saying this is your cause but something weird that can cause that.
Old Feb 28, 2010 | 07:38 PM
mbz connexion's Avatar
Interesting one for the log book.
Old Mar 1, 2010 | 07:34 AM
inkpusher's Avatar
Default Thanks
I really appreciate the info.
ontheball247
Jul 4, 2021 10:03 AM
inkpusher
Feb 15, 2010 05:06 PM
mercstyled
Jan 11, 2006 11:09 PM
gkm24
Feb 24, 2005 12:43 PM
