2002 c240 help please!!!
Old Aug 9, 2022 | 09:01 PM
Kevobenz1's Avatar
Default 2002 c240 help please!!!
Hey everyone I have a 2002 c240. I’m having a few issues with it.
1 engine has a misfire really bad. Pulled the codes and says cyl 3-6 misfire and then random misfire
coils plugs wires and maf have all been changed
2 the car will not shift gears. That is to say if I run it for 5 min the indicator on the dash will not show what gear your in When going from drive to park you can only go to neutral then you have to shut the car off so you can get it in park If I rest the codes then it works as it should.
honestly I suspect the ecm to be bad or a huge wiring issue. There are also little things like the speedo says the low beam lights are out but they are not the horn works when it wants and a few other things.
when I pull the codes just about every on the car throws at least 5 codes some throw 20 or more.
any thought on this. ??
pscreech
Sep 7, 2017 12:36 PM
Benzito88
May 5, 2013 11:47 PM
mbbellamy
Jan 16, 2008 11:20 PM
Benzito88
Jan 10, 2008 01:03 AM
habalmd
Nov 9, 2007 05:52 PM
