2002 C230K radio
Old Sep 10, 2009 | 04:21 PM
aldin's Avatar
Default 2002 C230K radio
I recently replaced myself the alternator. Now the SRS light is on, the radio is completely dead, the sunroof does not open and it is difficult to open the door with the remote. Can anyone help?
Old Sep 11, 2009 | 04:43 PM
mrcoyote's Avatar
When you disconnect the battery, it puts a lot of things out of synch. To do the windows, turn the key to the ignition position (don't start it) and push down and HOLD each window switch for about 5 seconds and then release. This will make the windows go up and down with one-touch again. The same for the sunroof and/or rear window shade if you have one of those. Turn the key on and push the sunroof button and HOLD it five seconds or a bit more. This will make it work properly. Try this with the radio and the remote. I'm not sure this is the procedure for the remote, but it probably is. Hope this helps out.
N8TVNYR
Feb 28, 2010 02:02 AM
jcv177
Sep 16, 2006 11:24 AM
mbgt
May 16, 2006 10:32 PM
Andre_han
Feb 1, 2006 05:59 PM
shinsain
Oct 12, 2005 11:18 PM
