1999 C280 No Start
Ok, went through every post I could find and still cant get it to start!
Replaced: Fuel pump, fuel pump relay, K40 assembly, Crank Position Sensor, Battery. It cranks just fine, just won't fire up. Don't drive it much and it sat for about a month then this started happening. Any gurus out there? Thanks Kelly |
Hi Kelly - have you tried pulling the fault codes to see where the issue is coming from?
Code 1570
shows code 1570 now. Looks bad |
Originally Posted by mrfuser
(Post 176377)
shows code 1570 now. Looks bad Take a look at the link below to one of the threads on our forum where a user found a solution. Hope this helps you a bit. W202 P1570 DAS Fault - Solution - PeachParts Mercedes-Benz Forum |
